はじめに
This detailed guide will cover the particulars on how to replace the Antenna Grille in the event it becomes damaged or does not open.
必要な工具と部品
Power off the Star trek Bluetooth Communicator before disassembling by holding down the left button for five seconds. A "woosh-down" sound indicates the power is going off, and no lights will blink.
Remove the antenna grill.
I just want to note that re-installing the grille (or installing a replacement) can be very tricky. Especially that little spring. Like the original poster said, you can't let those little pins fall out of the ends, but you have to find a way to get that little spring in just the right position or it might fall out. The pin that holds the spring must be pushed as far to the right (from the back of the communicator) as it will go and the spring must be installed onto the pin with the little bent arm on the left. As you position the grille into place, the little bent arm on the left of the spring must be pushed past the small stopping point molded into the inside of the front half of the communicator case. I hope this helps.
3 の人々がこのガイドを完成させました。
3 件のコメント
Really?!
I tried this tonight and I now have a bag of useless components. You made no mention of the SPRING on the antenna grille which flew off on removal of the grille and then I had no idea which way it was located on re-assembly. I guessed the orientation then couldn’t get the metal plate to fit back on. That led to me snapping one of the hair thin wires! I now have £120 of junk components. Thanks a lot!
Where can we get a replacement grille?
I know this post is more than a year old, but I was able to contact the Wand Company and purchase a replacement grille from them.
gschyve -
