メインコンテンツにスキップ
はじめに
In this guide you will learn how to disassemble and reassemble the trimmer and learn how to replace the blades if they needed to be fixed.
  1. Start with examining the razor, looking to see if the blades are jammed or moving.
    • Start with examining the razor, looking to see if the blades are jammed or moving.
  2. By now you've realized that the blades are broken and need to replace them. Unscrew the top two screws with a Philips head screwdriver.
    • By now you've realized that the blades are broken and need to replace them. Unscrew the top two screws with a Philips head screwdriver.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Apply pressure to the back side of the blades and remove the blades. Apply pressure to the back side of the blades and remove the blades.
    • Apply pressure to the back side of the blades and remove the blades.
  5. In this step remove metal clip by using either a flat head or Philips head screwdriver. In this step remove metal clip by using either a flat head or Philips head screwdriver.
    • In this step remove metal clip by using either a flat head or Philips head screwdriver.
    Any chance of getting a clearer, closer, better lit shot of the assembled head? Mine has fallen apart, and this is the closest I have found to a picture of what it should look like. If only it were clearer...
    Nicholas Sterling - 返信
  6. Once taken completely apart this is what you will be looking at. What you need to replace is the metal clip shown in the picture. Once replacing the clip, reassemble the razor and the problem is now solved.
    • Once taken completely apart this is what you will be looking at. What you need to replace is the metal clip shown in the picture. Once replacing the clip, reassemble the razor and the problem is now solved.
まとめ
nathan
メンバー登録日: 2013年10月22日
1,150 ポイント
6のガイドは作成済み
チーム
University of Maryland, Team 1-3, Shastany Fall 2013 University of Maryland, Team 1-3, Shastany Fall 2013人のメンバー
UMD-SHASTANY-F13S1G3
3 メンバー
6のガイドは作成済み
Where can I get replacement arms?
Sam - 返信
Where can one obtain a new spring???
tinkrmann - 返信
Where can one acquire a new spring??
tinkrmann - 返信
コメントを追加する
統計データを表示:
過去 24時間: 7
過去 7 日: 24
過去 30 日: 101
今までの合計 8,163
