メインコンテンツにスキップ
Wacom Intuos4 Touch Ring Replacement
必要な工具と部品
  1. Wacom Intuos4 Touch Ring Replacement, Casing: 手順 1、 3の画像 1 Wacom Intuos4 Touch Ring Replacement, Casing: 手順 1、 3の画像 2 Wacom Intuos4 Touch Ring Replacement, Casing: 手順 1、 3の画像 3
    • Flip device on its back and remove all fourteen 7.1 mm screws using a Phillips #1 screwdriver.
    • There is a single screw located under each of the rubber leg pieces. Use a shimmy tool to remove these pieces to access the screws.
  2. Wacom Intuos4 Touch Ring Replacement: 手順 2、 2の画像 1 Wacom Intuos4 Touch Ring Replacement: 手順 2、 2の画像 2
    • Lift the screen's foam backing connecting the motherboard/drawing board to the two smaller express-key boards, placing it onto the motherboard.
    • Separate the outer casing from the rest of the tablet.
  3. Wacom Intuos4 Touch Ring Replacement, Motherboard: 手順 3、 2の画像 1 Wacom Intuos4 Touch Ring Replacement, Motherboard: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers, remove the yellow tape covering the three cable connectors.
  4. Wacom Intuos4 Touch Ring Replacement: 手順 4、 2の画像 1 Wacom Intuos4 Touch Ring Replacement: 手順 4、 2の画像 2
    • Lift the black plastic clip holding the flat wire to the connector with either tweezers or an iFixit opening tool.
    • Pull on the white plastic tab to disconnect the flat wire.
  5. Wacom Intuos4 Touch Ring Replacement: 手順 5、 2の画像 1 Wacom Intuos4 Touch Ring Replacement: 手順 5、 2の画像 2
    • Carefully remove the motherboard from the casing.
    • If you're having trouble, don't force it. Make sure all cables are disconnected and all screws are removed.
  6. Wacom Intuos4 Touch Ring Replacement, Touch Ring: 手順 6、 2の画像 1 Wacom Intuos4 Touch Ring Replacement, Touch Ring: 手順 6、 2の画像 2
    • Remove the plastic tracking ball by lifting it up and out of its slot.
  7. Wacom Intuos4 Touch Ring Replacement: 手順 7、 1の画像 1
    • Use an iFixit opening tool to gently lift the circuit board from the slot.
    • If the touch ring doesn't come out immediately, do not force it or you may cause damage to the device. If it is difficult to remove, heat the front face of the touch ring to loosen the glue that holds it in.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Lillian Avery
メンバー登録日: 10/26/22
91 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 3-6, Botvin Fall 2022 UMass Dartmouth, Team 3-6, Botvin Fall 2022人のメンバー
UMASSD-BOTVIN-F22S3G6
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 166
