はじめに
by the end of the guide you will have replaced your power supply
必要な工具と部品
Procurement of a suitable commercially available power pack.
Type GST120A24R7B
R7B is important as this is the only connector that fits the Wacom tablet. (Connector type KYCON KPPX-4).
Performance data 120W, 24 volts
The power pack opens. To do this, the four rubber plugs are removed and the four screws are removed with a Phillips screwdriver. The housing can then be easily removed.
The 24V side has four wires: black, blue, red and white. These are soldered and can be removed.
The black and blue wire is soldered to the minus output (V-). The red and white wire is soldered to the 24V (V+) output. Note: The black wire is connected to the metal body of the plug.
The power supply will reassemble and can now be connected to the Wacom Tablet.
Work the steps in reverse order to reassemble your device.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
HelloMacOSさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
