メインコンテンツにスキップ
Wacom Cintiq 24HD Display Control Buttons Replacement
必要な工具と部品
  1. Wacom Cintiq 24HD Display Control Buttons Replacement, Stand: 手順 1、 1の画像 1
    • Unplug any cables from the USB, power, display or DVI-D ports by gripping the cord by the connector and pulling straight out of the port.
    • Unplugging the cables by pulling on the cord or pulling at an angle can damage the cable or connector.
  2. Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 2、 3の画像 1 Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 2、 3の画像 2 Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 2、 3の画像 3
    • Place the device screen down on a flat surface.
    • Remove eight 10mm Phillips #2 screws (four on each leg of the stand) by turning the screwdriver counterclockwise.
  3. Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 3、 1の画像 1
    • Lift the stand up and away from the rest of the device so the legs separate from the mounting plate.
  4. Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 手順 4、 3の画像 1 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 手順 4、 3の画像 2 Wacom Cintiq 24HD Display Control Buttons Replacement, Back Panel: 手順 4、 3の画像 3
    • Remove eighteen 10.2mm Phillips #1 screws from the perimeter of the back panel by turning the screwdriver counterclockwise.
    • Remove one 11.9mm Phillips #1 screw from the center of the back panel.
    • Remove two 10.2mm Phillips #1 screws from underneath hinged panels in the bottom right and left corners.
    • Our device does not include the cover panels for the USB, DVI-D, and power ports. You must first remove these cover panels shown in green in order to remove the back panel.
  5. Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 5、 2の画像 1 Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 5、 2の画像 2
    • Lift the back panel up by a corner and insert a plastic opening tool in the gap.
    • Slide the tool along the gap around the perimeter of the device while lifting to unlatch the back panel.
    • The latches on the back panel will make loud clicking noises when opening.
    • Remove the panel by lifting it up and off of the device.
  6. Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 手順 6、 3の画像 1 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 手順 6、 3の画像 2 Wacom Cintiq 24HD Display Control Buttons Replacement, Display Control Buttons: 手順 6、 3の画像 3
    • Remove the two 8mm screws from the metal button plate using a Phillips #2 screwdriver and by turning clockwise.
    • Remove metal holding plate by lifting up and off of the button board.
  7. Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 7、 1の画像 1
    • Remove the button board by pinching the wiring close to the connector and gently pulling straight out from the port.
  8. Wacom Cintiq 24HD Display Control Buttons Replacement: 手順 8、 1の画像 1
    • Remove the button cover by pushing the buttons out of their holes and pulling the cover up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jay Sung
メンバー登録日: 10/08/18
481 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S15-G3, White Fall 2018 Cal Poly, Team S15-G3, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G3
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,487
