はじめに
Use this guide to remove or replace the impeller on a Wacker PG1 (2014) Pump.
必要な工具と部品
Before beginning repairs, disconnect and remove all hoses.
Flip the motor ignition switch into the OFF position.
Insert a flathead screwdriver between two fan blades on the motor fan assembly.
Tap the impeller on one of its blades with a rubber mallet and a punch to break it loose from the threads on the output shaft.
もう少しです!
終わりに
