メインコンテンツにスキップ
VuPoint DC-ST210-VP Shutter Button Replacement
必要な工具と部品
  1. VuPoint DC-ST210-VP Shutter Button Replacement, Turn Off/Remove Batteries: 手順 1、 1の画像 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 手順 2、 3の画像 1 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 手順 2、 3の画像 2 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Screws: 手順 2、 3の画像 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: 手順 3、 2の画像 1 VuPoint DC-ST210-VP Shutter Button Replacement, Pry Backplate Off: 手順 3、 2の画像 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: 手順 4、 2の画像 1 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Circuit Board: 手順 4、 2の画像 2
    • With the back plate off, use a screw driver to remove the 6 screws shown to the left.
    • Gently separate the circuit board from frame, by prying the circuit board from base.
  5. VuPoint DC-ST210-VP Shutter Button Replacement, Move Plastic Protector: 手順 5、 1の画像 1
    • Using your finger rotate the dark grey piece away from the shutter button.
  6. VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: 手順 6、 2の画像 1 VuPoint DC-ST210-VP Shutter Button Replacement, Remove Shutter Button: 手順 6、 2の画像 2
    • Remove the shutter button by gently pressing the button from the top, pushing it towards the inside of the camera. Press shutter button down and wiggle slightly until the shutter button comes loose from housing.
    • Replace as necessary.
終わりに
作成者
2人の作成者と共同で作成されました。
Lincoln Thompson
メンバー登録日: 10/20/14
32 ポイント
2のガイドは作成済み
チーム
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G15
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 257
