メインコンテンツにスキップ
VuPoint DC-ST210-VP LCD Screen Replacement
必要な工具と部品
  1. VuPoint DC-ST210-VP LCD Screen Replacement, Turn Off/Remove Batteries: 手順 1、 1の画像 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: 手順 2、 3の画像 1 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: 手順 2、 3の画像 2 VuPoint DC-ST210-VP LCD Screen Replacement, Remove Screws: 手順 2、 3の画像 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: 手順 3、 2の画像 1 VuPoint DC-ST210-VP LCD Screen Replacement, Pry Backplate Off: 手順 3、 2の画像 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP LCD Screen Replacement, Remove Circuit Board Screws: 手順 4、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $16.96
    • Using a Phillips #00 screwdriver, remove the 5 (3.5mm in length) screws shown to the left.
    • Remember to place small screws on magnetic mat or in a container.
  5. VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: 手順 5、 3の画像 1 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: 手順 5、 3の画像 2 VuPoint DC-ST210-VP LCD Screen Replacement, Seperate Circuit Board: 手順 5、 3の画像 3
    • Using a pry tool or fingernail, gently pry the circuit board from the base.
    • Gently lift the lower right hand corner of the circuit board, separating it from the base.
  6. VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: 手順 6、 3の画像 1 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: 手順 6、 3の画像 2 VuPoint DC-ST210-VP LCD Screen Replacement, Remove LCD from Connector: 手順 6、 3の画像 3
    この手順で使用する道具:
    • Locate LCD and gently bend it back to reveal ribbon cable connector.
    • Using small screw driver or tweezers gently slide the edges of the ribbon lock towards the direction of the cable.
    • Once the lock is opened, use tweezers to slide the ribbon cable from the connector.
    • Replace LCD as needed and repeat steps in reverse to reassemble.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Lincoln Thompson
メンバー登録日: 10/20/14
32 ポイント
2のガイドは作成済み
チーム
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G15
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 518
