メインコンテンツにスキップ
VuPoint DC-ST210-VP Battery Door Cover Replacement
必要な工具と部品
  1. VuPoint DC-ST210-VP Battery Door Cover Replacement, Turn Off/Remove Batteries: 手順 1、 1の画像 1
    • Hold the on/off button for 3 seconds until the screen is black.
    • Remove batteries by placing thumb on battery plate cover sliding it down to expose batteries.
    • Turn camera upside down to allow the batteries to fall out.
  2. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: 手順 2、 3の画像 1 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: 手順 2、 3の画像 2 VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Screws: 手順 2、 3の画像 3
    • There are 5 (4.5mm in length) screws on the sides of the camera that need to be removed. Use a Phillips #000 screwdriver to remove all screws.
    • Remove 2 screws on the right side of the camera, and store them on a magnetic mat.
    • Remove 2 screws on the bottom of the camera, and store them on a magnetic mat.
    • Remove 1 screw on the left side of the camera, and store it on a magnetic mat.
  3. VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: 手順 3、 2の画像 1 VuPoint DC-ST210-VP Battery Door Cover Replacement, Pry Backplate Off: 手順 3、 2の画像 2
    • Using a prying tool or fingernail, gently separate the back plate from the front plate, exposing the inside of the camera.
  4. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove Battery Case Screw: 手順 4、 1の画像 1
    • Remove the 4.5mm screw with the iFixit ph#00 screwdriver
  5. VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: 手順 5、 2の画像 1 VuPoint DC-ST210-VP Battery Door Cover Replacement, Open the Battery Case: 手順 5、 2の画像 2
    • With your fingers, gently pull the two pieces of the battery case apart. At this point, the battery door should be exposed
  6. VuPoint DC-ST210-VP Battery Door Cover Replacement, Remove the Battery Cover: 手順 6、 1の画像 1
    • With your fingers, gently remove the battery door.
    • Now you are free to repair or replace the battery door! Follow these steps in reverse order to reassemble the camera.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Elise Brown
メンバー登録日: 10/26/14
70 ポイント
2のガイドは作成済み
チーム
Baylor, Team 8-15, Williams Fall 2014 Baylor, Team 8-15, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G15
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 13
今までの合計 367
