メインコンテンツにスキップ
Vtech kidizoom camera disassembly
必要な工具と部品
  1. Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 手順 1、 3の画像 1 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 手順 1、 3の画像 2 Vtech kidizoom camera disassembly, Vtech kidizoom camera disassembly: 手順 1、 3の画像 3
    • Camera
    Thanks, this is also the key to success for the “kidizoom duo dx”: Remove the “Mega Pixel” paper shield: There are four more claws attached at the battery case, then remove the screws and you can pry it open.
    Kajetan Hinner - 返信
  2. Vtech kidizoom camera disassembly: 手順 2、 3の画像 1 Vtech kidizoom camera disassembly: 手順 2、 3の画像 2 Vtech kidizoom camera disassembly: 手順 2、 3の画像 3
    • push and open
  3. Vtech kidizoom camera disassembly: 手順 3、 3の画像 1 Vtech kidizoom camera disassembly: 手順 3、 3の画像 2 Vtech kidizoom camera disassembly: 手順 3、 3の画像 3
    • Insérer un commentaire.
  4. Vtech kidizoom camera disassembly: 手順 4、 3の画像 1 Vtech kidizoom camera disassembly: 手順 4、 3の画像 2 Vtech kidizoom camera disassembly: 手順 4、 3の画像 3
  5. Vtech kidizoom camera disassembly: 手順 5、 1の画像 1
終わりに
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
12 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
olixcomtest
メンバー登録日: 11/06/16
356 ポイント
1ガイドが承認済み
2 件のコメント
In the very first step be aware that the you just need to remove the paper ring. In the photo above this is pink and on mine it was orange.
I made the mistake of thinking I had to use some force with a screwdriver, to remove the ring on the front, which resulted in me scratching the chrome ring.
Once you have removed the paper ring, you can see the screws (or they may be under the left over sticky backing to the paper but are easy to find).
These photos were extremely helpful and I was able to repair the camera.
The problem with mine, was that it would not switch on. We replaced the batteries, but still no good.
After using the above photos, I opened the camera and discovered that one of the two cables to one of the battery holders, had come loose.
In the process of resoldering the broken cable, the second battery cable also came off … mainly due to the use of VERY thin wire and minimum solder.
Anyway, the camera is now working again and my son is very happy.
Chris - 返信
Thank you! It worked great with the Kidizoom Touch 5.0, Same principle. The Trigger was Stuck and with your instruction i was able to Open and fix it!
Flo - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 63
過去 30 日: 236
今までの合計 10,429
