メインコンテンツにスキップ
Vtech Move and Crawl Ball Power Switch Replacement
必要な工具と部品
  1. Vtech Move and Crawl Ball Power Switch Replacement, Battery: 手順 1、 2の画像 1 Vtech Move and Crawl Ball Power Switch Replacement, Battery: 手順 1、 2の画像 2
    • There are two screws that require a 4.0mm flat head screwdriver. Twist them counter clockwise to remove. When you remove them they stay contained within the blue outer case.
  2. Vtech Move and Crawl Ball Power Switch Replacement: 手順 2、 3の画像 1 Vtech Move and Crawl Ball Power Switch Replacement: 手順 2、 3の画像 2 Vtech Move and Crawl Ball Power Switch Replacement: 手順 2、 3の画像 3
    • Pry the batteries out with your finger. When you replace them be sure to orient them correctly according to the markings in the slots. Match the plus symbol on the battery to the plus symbol in the slot.
  3. Vtech Move and Crawl Ball Power Switch Replacement, Motor: 手順 3、 3の画像 1 Vtech Move and Crawl Ball Power Switch Replacement, Motor: 手順 3、 3の画像 2 Vtech Move and Crawl Ball Power Switch Replacement, Motor: 手順 3、 3の画像 3
    • Remove 6 screws in order to pop off the outer shell and reach the inside components.
  4. Vtech Move and Crawl Ball Power Switch Replacement: 手順 4、 3の画像 1 Vtech Move and Crawl Ball Power Switch Replacement: 手順 4、 3の画像 2 Vtech Move and Crawl Ball Power Switch Replacement: 手順 4、 3の画像 3
    • Remove the motor by lifting it out of the shell, and find the attached wires at both ends: the circuit board and the motor itself. Use the soldering iron to remove the existing attachments by heating the solder joint with the solder iron tip while pulling on the wire.
    • Make sure the motor is aligned over the correct holes during reassembly.
  5. Vtech Move and Crawl Ball Power Switch Replacement, Power Switch: 手順 5、 1の画像 1
    • Unscrew the two screws to the power switch located beside the circuit board
  6. Vtech Move and Crawl Ball Power Switch Replacement: 手順 6、 3の画像 1 Vtech Move and Crawl Ball Power Switch Replacement: 手順 6、 3の画像 2 Vtech Move and Crawl Ball Power Switch Replacement: 手順 6、 3の画像 3
    • Remove the existing attachments at both ends of the wires with the soldering iron. Heat the solder joint with the solder iron tip and pull the wire.
終わりに
作成者
3人の作成者と共同で作成されました。
William Jones
メンバー登録日: 09/04/15
222 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-1, Sullivan Fall 2015 USF Tampa, Team 2-1, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S2G1
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 943
