メインコンテンツにスキップ
Vtech Kidibeats Drum Set White Drum Head Replacement
必要な工具と部品
  1. Vtech Kidibeats Drum Set White Drum Head Replacement, Back Panel: 手順 1、 1の画像 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 2、 1の画像 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 3、 1の画像 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 4、 1の画像 1
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 5、 1の画像 1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 6、 2の画像 1 Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 6、 2の画像 2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set White Drum Head Replacement, White Drum Head: 手順 7、 2の画像 1 Vtech Kidibeats Drum Set White Drum Head Replacement, White Drum Head: 手順 7、 2の画像 2
    • To replace the white drum head on the cymbal side, use a Phillips #00 screwdriver to loosen and remove the two 8 mm screws.
    • To replace the white drum head on the side opposite of the cymbal, use a Phillips #00 screwdriver to loosen and remove the two 8 mm screws.
    • The blue drums will fall after the screws are loosened. Be sure to brace the blue drums in this step in order to prevent damage to the connection points between the blue drum components and the motherboard.
  8. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 8、 1の画像 1
    • Loosen and remove the five 15 mm screws using a Phillips #2 screwdriver.
  9. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 9、 1の画像 1
    • Using your hands, remove the orange rim and white drum head from the blue base.
  10. Vtech Kidibeats Drum Set White Drum Head Replacement: 手順 10、 1の画像 1
    • Using your hands, pull apart the white drum head from the orange rim.
終わりに
作成者
1人の作成者と共同作成されました。
Aaron Klementowski
メンバー登録日: 02/09/16
820 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 2-8, Cagle Spring 2016 USF Tampa, Team 2-8, Cagle Spring 2016人のメンバー
USFT-CAGLE-S16S2G8
2 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 480
