メインコンテンツにスキップ
Vtech Kidibeats Drum Set Green Cymbal Replacement
必要な工具と部品
  1. Vtech Kidibeats Drum Set Green Cymbal Replacement, Back Panel: 手順 1、 1の画像 1
    • Locate the battery panel that is centered between the three leg supports at the bottom of the drum set.
  2. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 2、 1の画像 1
    • To remove the battery panel, loosen the 10 mm panel screw using a flathead 4.0 screwdriver.
    • You can also use a small coin to loosen the screw.
  3. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 3、 1の画像 1
    • Using your fingers, pry open and remove the back battery panel.
  4. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 4、 1の画像 1
    • Use your fingers to remove each battery from its housing.
  5. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 5、 1の画像 1
    • Using a Phillips #2 screwdriver, loosen and remove the six 14 mm screws.
  6. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 6、 2の画像 1 Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 6、 2の画像 2
    • With your hands, separate the bottom panel from the drum set.
    • When removing the bottom panel, be careful not to pull too hard in order to prevent damaging the connections from the motherboard to the speaker and power source.
  7. Vtech Kidibeats Drum Set Green Cymbal Replacement, Green Cymbal: 手順 7、 1の画像 1
    • Use Phillips #2 screwdriver to loosen and remove the single 16 mm screw.
  8. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 8、 1の画像 1
    • Using your hands, remove the blue cymbal stand from the orange base.
  9. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 9、 1の画像 1
    • Loosen and remove the two 14 mm screws using a Phillips #2 screwdriver.
  10. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 10、 1の画像 1
    • Using your hands, separate the two halves of the blue cymbal stand.
  11. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 11、 1の画像 1
    • Using your hands, separate the green cymbal from the blue cymbal base.
  12. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 12、 1の画像 1
    • Using a Phillips #00 screwdriver, loosen and remove the three 12 mm screws located on the bottom of the green cymbal.
  13. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 13、 1の画像 1
    • Using your hands, separate the green cymbal from the green cymbal base.
  14. Vtech Kidibeats Drum Set Green Cymbal Replacement: 手順 14、 1の画像 1
    • Using your hands, pull apart the green cymbal from the yellow light casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Aaron Klementowski
メンバー登録日: 02/09/16
820 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 2-8, Cagle Spring 2016 USF Tampa, Team 2-8, Cagle Spring 2016人のメンバー
USFT-CAGLE-S16S2G8
2 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 589
