メインコンテンツにスキップ
Vtech Innotab 3 Headphone Port Replacement
必要な工具と部品
  1. Vtech Innotab 3 Headphone Port Replacement, Rear Panel: 手順 1、 3の画像 1 Vtech Innotab 3 Headphone Port Replacement, Rear Panel: 手順 1、 3の画像 2 Vtech Innotab 3 Headphone Port Replacement, Rear Panel: 手順 1、 3の画像 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Headphone Port Replacement: 手順 2、 1の画像 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Headphone Port Replacement: 手順 3、 3の画像 1 Vtech Innotab 3 Headphone Port Replacement: 手順 3、 3の画像 2 Vtech Innotab 3 Headphone Port Replacement: 手順 3、 3の画像 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Headphone Port Replacement: 手順 4、 1の画像 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Headphone Port Replacement, Headphone Port: 手順 5、 3の画像 1 Vtech Innotab 3 Headphone Port Replacement, Headphone Port: 手順 5、 3の画像 2 Vtech Innotab 3 Headphone Port Replacement, Headphone Port: 手順 5、 3の画像 3
    この手順で使用する道具:
    • On the front panel of the device, the headphone poet is located at the bottom right corner of the device, opposte of the speaker.
    • Using tweezers, lift up to remove the headphone port from its holding.
    • Be careful not to tug too hard when removing the headphone port for you may disconnect the wires from the solder
  6. Vtech Innotab 3 Headphone Port Replacement: 手順 6、 3の画像 1 Vtech Innotab 3 Headphone Port Replacement: 手順 6、 3の画像 2 Vtech Innotab 3 Headphone Port Replacement: 手順 6、 3の画像 3
    • Use tweezers to hold the four connecting wires away from the headphone port.
    • Desolder the four wires connected to the headphone port.
    • This is a tricky step. Refer to this guide to learn how to solder: How To Solder and Desolder Connections
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Zach Diviney
メンバー登録日: 03/11/15
419 ポイント
4のガイドは作成済み
チーム
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G4
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 316
