メインコンテンツにスキップ
Vtech Innotab 3 Button Replacement
必要な工具と部品
  1. Vtech Innotab 3 Button Replacement, Rear Panel: 手順 1、 3の画像 1 Vtech Innotab 3 Button Replacement, Rear Panel: 手順 1、 3の画像 2 Vtech Innotab 3 Button Replacement, Rear Panel: 手順 1、 3の画像 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech Innotab 3 Button Replacement: 手順 2、 1の画像 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech Innotab 3 Button Replacement: 手順 3、 3の画像 1 Vtech Innotab 3 Button Replacement: 手順 3、 3の画像 2 Vtech Innotab 3 Button Replacement: 手順 3、 3の画像 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech Innotab 3 Button Replacement: 手順 4、 1の画像 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
  5. Vtech Innotab 3 Button Replacement, Button Repair: 手順 5、 3の画像 1 Vtech Innotab 3 Button Replacement, Button Repair: 手順 5、 3の画像 2 Vtech Innotab 3 Button Replacement, Button Repair: 手順 5、 3の画像 3
    • Remove the four 7.6 mm screws using a PH00 screwdriver.
    • Lift the circuit board up to give yourself room to remove the buttons.
  6. Vtech Innotab 3 Button Replacement: 手順 6、 3の画像 1 Vtech Innotab 3 Button Replacement: 手順 6、 3の画像 2 Vtech Innotab 3 Button Replacement: 手順 6、 3の画像 3
    • Using a nylon or metal spudger, lift up the buttons to remove them from their holding. they should just pop out of place.
    • The buttons are joined together in pairs, be sure not to break them apart during removal.
終わりに
作成者
3人の作成者と共同で作成されました。
Zach Diviney
メンバー登録日: 03/11/15
419 ポイント
4のガイドは作成済み
チーム
Colorado Springs, Team 5-4, Panko Spring 2015 Colorado Springs, Team 5-4, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G4
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 544
