はじめに
Is the speaker malfunctioning on your child's tablet? Does it need to be replaced? This guide will walk you through replacing the speaker on the Vtech InnoTab 3S.
必要な工具と部品
While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
Remove the batteries from the device.
Remove the six screws that secure the motherboard to the front panel of the device using a Phillips #1 screwdriver.
Remove the other 5mm screws that secure the charger port and the buttons to the inside of the front panel.
Remove the six 3 mm screws securing the battery clip.
Using a soldering iron, heat the connections securing the speakers to the motherboard of the device.
Remove the connections on the motherboard to detach the speaker.
ある他の人がこのガイドを完成しました。
