メインコンテンツにスキップ
Vtech InnoTab 3S Camera Replacement
必要な工具と部品
  1. Vtech InnoTab 3S Camera Replacement, Rear Panel: 手順 1、 3の画像 1 Vtech InnoTab 3S Camera Replacement, Rear Panel: 手順 1、 3の画像 2 Vtech InnoTab 3S Camera Replacement, Rear Panel: 手順 1、 3の画像 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Camera Replacement: 手順 2、 2の画像 1 Vtech InnoTab 3S Camera Replacement: 手順 2、 2の画像 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Camera Replacement: 手順 3、 3の画像 1 Vtech InnoTab 3S Camera Replacement: 手順 3、 3の画像 2 Vtech InnoTab 3S Camera Replacement: 手順 3、 3の画像 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Camera Replacement: 手順 4、 1の画像 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
  5. Vtech InnoTab 3S Camera Replacement, Camera: 手順 5、 2の画像 1 Vtech InnoTab 3S Camera Replacement, Camera: 手順 5、 2の画像 2
    • Using the tip of your finger, carefully pull the clip upwards to release the camera connection from the motherboard.
    • The connection between the motherboard and the camera is located at the near the top of the device.
    • Remove the camera and the connecting wire from the the clip and attach the replacement cameras connection to the latch on the motherboard.
    • Carefully lower the latch until you hear a click to secure the new camera to the device.
    • Pulling or tugging on the connection between the camera and the circuit board may cause damage to the connection.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Karina Garcia
メンバー登録日: 08/30/15
878 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 8-2, Eyestone Fall 2015 USF Tampa, Team 8-2, Eyestone Fall 2015人のメンバー
USFT-EYESTONE-F15S8G2
4 メンバー
9のガイドは作成済み
4件のガイドコメント
Where do you get the replacement camera? I can't find them online.
rongennero - 返信
I just did this whole thing...hoping it was a reset to the camera or something, but no, you need a replacement camera. Might be helpful to add that to the PARTS NEEDED part at the top, instead of saying "no parts required." UUGHHHH!
jpimash - 返信
Where can i buy the camera?
Stephan Meyer - 返信
kind of useless to post a replacement guide without suggesting a source for that replacement!!
Glen Fletcher - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 2,122
