はじめに
If your Voluas VL001 pet feeder's electric motor is working but your main drive gear isn't turning, you may have a problem with your motor assembly gears. This guide outlines how to replace them. It is a fairly simple process and can be done quickly.
必要な工具と部品
Remove the lid to the storage tank by using the latch and lifting off.
Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
Place your pet feeder upside down.
Squeeze the lock and remove the battery cover.
Remove the three 1.5V D alkaline batteries.
Insert a metal spudger under the adhesive part of each rubber foot.
Pry the foot off.
Using a Phillips #2 screwdriver, remove the six screws that hold the motor housing on to the device.
