はじめに
There are several problems that could be causing your Voluas VL001 pet feeder to not dispense food. One of the causes is a defective main drive gear. Replacing this part is simple and quick.
必要な工具と部品
Remove the lid to the storage tank by using the latch and lifting off.
Grab the food storage tank on both sides. Depress the tabs that say "Push" on them and lift the tank off.
Place your pet feeder upside down.
Squeeze the lock and remove the battery cover.
Remove the three 1.5V D alkaline batteries.
Insert a metal spudger under the adhesive part of each rubber foot.
Pry the foot off.
Remove the two 11 mm screws that attach the portion switch to the device using a #2 Phillips screwdriver.
