メインコンテンツにスキップ
パーツ
パーツは指定されていません。
  1. Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons. Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Look into the tablet for loose connectors.
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Remove screw with the J1 screwdriver or screw bit. Screw has a 3.66 mm head and is 3.5 mm tall.
    • Remove screw with the J1 screwdriver or screw bit.
    • Screw has a 3.66 mm head and is 3.5 mm tall.
  4. Lift the flap hiding second screw. Remove the screw by using J1 screwdriver. Screw has a 3.66 mm head and is 3.5 mm tall.
    • Lift the flap hiding second screw.
    • Remove the screw by using J1 screwdriver.
  5. Disconnect the black and red cable connector from the camera strip. Using tweezers may help to grab the small connector flanges. Using tweezers may help to grab the small connector flanges.
    • Disconnect the black and red cable connector from the camera strip.
    • Using tweezers may help to grab the small connector flanges.
  6. Disconnect the ribbon cable from the camera circuit board by lifting it away from circuit board. A spudger may help with leverage when removing the ribbon cable. A spudger may help with leverage when removing the ribbon cable.
    • Disconnect the ribbon cable from the camera circuit board by lifting it away from circuit board.
    • A spudger may help with leverage when removing the ribbon cable.
終わりに
Gilberto Ambriz
メンバー登録日: 2016年09月29日
546 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Crane Fall 2016 Eastern Washington University, Team 1-1, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
