はじめに
Hello! This guide will show you how to replace the battery in a Vizio VTAB1008.
必要な工具と部品
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
