メインコンテンツにスキップ
Vizio VTAB1008 Battery Replacement
必要な工具と部品
  1. Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: 手順 1、 2の画像 1 Vizio VTAB1008 Battery Replacement, Vizio VTAB1008 Back Cover Removal: 手順 1、 2の画像 2
    • Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
    • Do not insert the opening tool too far into the tablet as this can damage connectors close to edges of the cover.
    • The angled tip of the opening tool can be wedged into the device by pressing on the back of the opening tool with the thumb. Move the opening tool in a sliding motion to ensure all tabs separate.
    • Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
  2. Vizio VTAB1008 Battery Replacement: 手順 2、 1の画像 1
    • Look into the tablet for loose connectors.
    • There are three loose connectors: one for the screen, one for the digitizer, and one for the motherboard. They are held in place by the pressure of the backing and screen assemblies.
    • Flip the backing from the button-less side over, being careful not to separate the ribbon connector from the display screen.
  3. Vizio VTAB1008 Battery Replacement, Battery: 手順 3、 3の画像 1 Vizio VTAB1008 Battery Replacement, Battery: 手順 3、 3の画像 2 Vizio VTAB1008 Battery Replacement, Battery: 手順 3、 3の画像 3
    • Remove the ribbon strip that crosses the battery from both ends.
    • A blue opening tool may be used to assist.
  4. Vizio VTAB1008 Battery Replacement: 手順 4、 2の画像 1 Vizio VTAB1008 Battery Replacement: 手順 4、 2の画像 2
    • Remove the connector at the top of the motherboard by pulling out and away from the motherboard.
    • This is the connector with the wires leading to the battery.
    • Tweezers may help.
  5. Vizio VTAB1008 Battery Replacement: 手順 5、 3の画像 1 Vizio VTAB1008 Battery Replacement: 手順 5、 3の画像 2 Vizio VTAB1008 Battery Replacement: 手順 5、 3の画像 3
    • Pull the battery away from the back panel.
    • A metal spudger may be needed to pry the battery from the backing.
    • The battery is glued to the back panel and caution should be used as to not break or rupture the battery pack.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Gilberto Ambriz
メンバー登録日: 09/29/16
546 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-1, Crane Fall 2016 Eastern Washington University, Team 1-1, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,324
