メインコンテンツにスキップ
Vizio SmartCast Tablet Remote XR6P Power Button Replacement
必要な工具と部品
  1. Vizio SmartCast Tablet Remote XR6P Power Button Replacement, Back Cover: 手順 1、 1の画像 1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 手順 2、 1の画像 1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 手順 3、 1の画像 1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Power Button Replacement, Power Button: 手順 4、 1の画像 1
    • Using the pointy end of the black plastic spudger, carefully remove the black tape covering the plug.
  5. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 手順 5、 2の画像 1 Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 手順 5、 2の画像 2
    • Use the flat end of the spudger to pry the ribbon holder upwards.
  6. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Obtain the tweezers and gently pull the black ribbon until it comes out of the holder.
  7. Vizio SmartCast Tablet Remote XR6P Power Button Replacement: 手順 7、 1の画像 1
    • Continue pulling the black tab until you have completely removed the power button from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Wilmer Arriaga
メンバー登録日: 10/04/18
159 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team S2-G5, Karnes Fall 2018 Linn Benton Community College, Team S2-G5, Karnes Fall 2018人のメンバー
LBCC-KARNES-F18S2G5
3 メンバー
12のガイドは作成済み
1件のガイドコメント
you can perform the operation since when you shake the tablet listening that something moves in the area of ​​the power button, the tablet does not turn on by pressing the button, I have to connect the charger and now press the button and the tablet turns on, already on the device pressed power button and the menu appears shutdown and reboot, actually I don't know what the problem is.
miguel anhel Hernandez - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 478
