メインコンテンツにスキップ
Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement
必要な工具と部品
  1. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Back Cover: 手順 1、 1の画像 1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 2、 1の画像 1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 3、 1の画像 1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
  4. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Micro USB Charging Port: 手順 4、 2の画像 1 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement, Micro USB Charging Port: 手順 4、 2の画像 2
    この手順で使用する道具:
    • The black ribbon can be easily damaged during this step, so proceed with caution.
    • Place the flat end of the black plastic spudger under the black plug and pry up to release the black ribbon. Using the metal tweezers, pull the black ribbon out of the plug.
  5. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 5、 1の画像 1
    • Remove all three 3mm-long silver screws using the T5 Torx screwdriver.
  6. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 6、 3の画像 1 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 6、 3の画像 2 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 6、 3の画像 3
    • Place the shovel end of the metal spudger under the speaker and pry upwards to remove the speaker from the device.
    • The speaker is secured to the device with adhesive glue so you may hear cracking noises while prying with the spudger.
  7. Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 7、 2の画像 1 Vizio SmartCast Tablet Remote XR6P Micro USB Charging Port Replacement: 手順 7、 2の画像 2
    • Using the tweezers, grab a hold of the Micro USB assembly and gently remove it from the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Jordan Adams
メンバー登録日: 10/04/18
445 ポイント
4のガイドは作成済み
チーム
Linn Benton Community College, Team S2-G5, Karnes Fall 2018 Linn Benton Community College, Team S2-G5, Karnes Fall 2018人のメンバー
LBCC-KARNES-F18S2G5
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 346
