はじめに
This guide will help you replace the “ok” button on your Vizio t.v remote controller. The “ok” button is a key button on this controller because, without it, you won’t be able to select anything on your t.v screen. Please make sure to remove the battery before taking apart the remote.
必要な工具と部品
この手順で使用する道具:iFixit Opening Tool$1.99
Use the plastic opening tool to unlock the device. Place the tool in the thin space that separates the base from the control panel.
ある他の人がこのガイドを完成しました。
