Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
You will find one screw on the top, one on the bottom, and one on each side of the camera.
Put the screws in a safe place so you can find them and put them back in later.
Locate the power button on the top of the camera.
Using tweezers, gently remove the black plastic cover from the power button.
Using a soldering kit, de-solder the black and red wire from the silver power button.
Solder the new power button to the black and red wire.
To avoid burns, be careful of the heat from the soldering iron.
Reference the soldering guide for assistance!
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
