メインコンテンツにスキップ
Vivitar DVR 781HD Screen Replacement
必要な工具と部品
  1. Vivitar DVR 781HD Screen Replacement, Front Case: 手順 1、 3の画像 1 Vivitar DVR 781HD Screen Replacement, Front Case: 手順 1、 3の画像 2 Vivitar DVR 781HD Screen Replacement, Front Case: 手順 1、 3の画像 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Screen Replacement: 手順 2、 1の画像 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Screen Replacement: 手順 3、 3の画像 1 Vivitar DVR 781HD Screen Replacement: 手順 3、 3の画像 2 Vivitar DVR 781HD Screen Replacement: 手順 3、 3の画像 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Screen Replacement, Motherboard: 手順 4、 2の画像 1 Vivitar DVR 781HD Screen Replacement, Motherboard: 手順 4、 2の画像 2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Screen Replacement: 手順 5、 1の画像 1
    • Gently lift the motherboard, handling it by the edges.
  6. Vivitar DVR 781HD Screen Replacement, Screen: 手順 6、 2の画像 1 Vivitar DVR 781HD Screen Replacement, Screen: 手順 6、 2の画像 2
    • Remove the two 4mm Phillips #1 screws holding the screen assembly to the motherboard.
  7. Vivitar DVR 781HD Screen Replacement: 手順 7、 2の画像 1 Vivitar DVR 781HD Screen Replacement: 手順 7、 2の画像 2
    • Turn the motherboard and screen over.
    • Gently lift the screen from the motherboard, handling it by the edges of the black plastic holder.
  8. Vivitar DVR 781HD Screen Replacement: 手順 8、 1の画像 1
    • Using a soldering iron, melt the solder connection between the screen's ribbon cable and the motherboard. Pull the ribbon cable away before the solder solidifies.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nathan McDaniel
メンバー登録日: 02/13/16
592 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S54G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 554
