メインコンテンツにスキップ
Vivitar DVR 781HD Battery Replacement
必要な工具と部品
  1. Vivitar DVR 781HD Battery Replacement, Front Case: 手順 1、 3の画像 1 Vivitar DVR 781HD Battery Replacement, Front Case: 手順 1、 3の画像 2 Vivitar DVR 781HD Battery Replacement, Front Case: 手順 1、 3の画像 3
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Battery Replacement: 手順 2、 1の画像 1
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Battery Replacement: 手順 3、 3の画像 1 Vivitar DVR 781HD Battery Replacement: 手順 3、 3の画像 2 Vivitar DVR 781HD Battery Replacement: 手順 3、 3の画像 3
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  4. Vivitar DVR 781HD Battery Replacement, Motherboard: 手順 4、 2の画像 1 Vivitar DVR 781HD Battery Replacement, Motherboard: 手順 4、 2の画像 2
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  5. Vivitar DVR 781HD Battery Replacement: 手順 5、 1の画像 1
    • Gently lift the motherboard, handling it by the edges.
  6. Vivitar DVR 781HD Battery Replacement, Battery: 手順 6、 2の画像 1 Vivitar DVR 781HD Battery Replacement, Battery: 手順 6、 2の画像 2
    • The battery connections are reinforced by black potting compound. Gently pry it away with a plastic spudger.
    • Be very careful with this step, as applying too much force can damage the motherboard or the components on it.
  7. Vivitar DVR 781HD Battery Replacement: 手順 7、 1の画像 1
    • Melt the soldered battery connections with a soldering iron and gently pull the battery wires away.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Nathan McDaniel
メンバー登録日: 02/13/16
592 ポイント
3のガイドは作成済み
チーム
IUPUI, Team 54-6, Wilson Spring 2016 IUPUI, Team 54-6, Wilson Spring 2016人のメンバー
IUPUI-WILSON-S16S54G6
3 メンバー
10のガイドは作成済み
2 件のコメント
Where can I get a battery
Albert Einstein - 返信
Any 3.7v Lithium Ion cell will work, truth be told, but if you google the writing you find on the factory battery once you open it, you will likely find dozens of vendors on ebay, amazon, alibaba, wish, etc. personally, i removed the battery and ran leads from the factory battery wires to an external battery pack that holds an 18650 cell which significantly increased available maH
undwirtanzten -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 65
今までの合計 5,924
