メインコンテンツにスキップ
Visual Land Prestige Pro 7D Camera Replacement
必要な工具と部品
  1. Visual Land Prestige Pro 7D Camera Replacement, Back Panel: 手順 1、 1の画像 1
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Camera Replacement: 手順 2、 1の画像 1
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: 手順 3、 2の画像 1 Visual Land Prestige Pro 7D Camera Replacement, Front-Facing Camera: 手順 3、 2の画像 2
    • Remove the black pad on the back of the camera by peeling it off.
  4. Visual Land Prestige Pro 7D Camera Replacement: 手順 4、 1の画像 1
    • With the bottom of the device facing away from you, pull the camera out of its black housing.
    • The camera will come right out when you lift with your fingers.
  5. Visual Land Prestige Pro 7D Camera Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    • Use the tweezers to lift the grey connector, connecting the camera ribbon to the circuit board, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
終わりに
作成者
3人の作成者と共同で作成されました。
Brandon Kodama
メンバー登録日: 10/17/14
229 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G41
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 566
