メインコンテンツにスキップ
Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement
必要な工具と部品
  1. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 手順 1、 1の画像 1
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connections begin to loosen.
  2. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 2、 1の画像 1
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast
  3. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 3、 2の画像 1 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 3、 2の画像 2
    • Once all connections have been loosened and using a soft surface, place the device onto its screen.
    • Open the casing and lay as shown keeping the speaker wire loose, and the camera component is highlighted in red.
  4. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 4、 3の画像 1 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 4、 3の画像 2 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 4、 3の画像 3
    • Using hook tweezers, gently separate the glued cameras away from the circuit board.
    • Allow each camera to rest on circuit board while proceeding to the ZIF (zero insertion force) on the circuit board.
    • Avoid touching camera lens with the tweezers.
  5. Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 5、 2の画像 1 Visual Land Prestige Elite 9Q Front and Rear Facing Camera Replacement: 手順 5、 2の画像 2
    • Maneuver the hook tweezers to flip up the black hinged ZIF connector to disconnect camera module.
    • After ZIF connector is flipped up, the camera module may be removed.
終わりに
作成者
3人の作成者と共同で作成されました。
Aaron
メンバー登録日: 07/19/16
316 ポイント
2のガイドは作成済み
チーム
University of Memphis, Team 1-1, Kim SU 2016 University of Memphis, Team 1-1, Kim SU 2016人のメンバー
UM-KIM-SU16S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 298
