メインコンテンツにスキップ
Visual Land Prestige 7L Front Facing Camera Replacement
必要な工具と部品
  1. Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: 手順 1、 2の画像 1 Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Front Facing Camera Replacement: 手順 2、 3の画像 1 Visual Land Prestige 7L Front Facing Camera Replacement: 手順 2、 3の画像 2 Visual Land Prestige 7L Front Facing Camera Replacement: 手順 2、 3の画像 3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Front Facing Camera Replacement: 手順 3、 3の画像 1 Visual Land Prestige 7L Front Facing Camera Replacement: 手順 3、 3の画像 2 Visual Land Prestige 7L Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: 手順 4、 2の画像 1 Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: 手順 4、 2の画像 2
    • Remove the adhesive padding.
  5. Visual Land Prestige 7L Front Facing Camera Replacement: 手順 5、 2の画像 1 Visual Land Prestige 7L Front Facing Camera Replacement: 手順 5、 2の画像 2
    • Unclip the connector that attaches the camera to the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Do not pull on the camera until you're sure that it's unclipped, the gold connection will rip.
    • Gently pop the camera out of the connector and off the case.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Greg Azzalina
メンバー登録日: 01/28/15
263 ポイント
1ガイドが承認済み
チーム
Penn State, Team 2-25, Kaschak Winter 2015 Penn State, Team 2-25, Kaschak Winter 2015人のメンバー
PSU-KASCHAK-W15S2G25
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 12
今までの合計 285
