必要な工具と部品
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
Gently grip and pull up the front camera, covered by protective adhesive foam.
Set aside the Camera housing.
もう少しです!
終わりに
