必要な工具と部品
この手順で使用する道具:Magnetic Project Mat$19.95
Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
Gently grip and pull up the front camera, covered by protective adhesive foam.
Set aside the Camera housing.
Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
Set aside the LCD Assembly.
4 の人々がこのガイドを完成させました。
