メインコンテンツにスキップ
Visioneer OneTouch 7400 USB Motherboard Replacement
必要な工具と部品
  1. Visioneer OneTouch 7400 USB Motherboard Replacement, Outer Case: 手順 1、 1の画像 1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 2、 2の画像 1 Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 3、 3の画像 1 Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 3、 3の画像 2 Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 3、 3の画像 3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 4、 1の画像 1
    • Separate the two casement pieces.
  5. Visioneer OneTouch 7400 USB Motherboard Replacement, Motherboard: 手順 5、 2の画像 1 Visioneer OneTouch 7400 USB Motherboard Replacement, Motherboard: 手順 5、 2の画像 2
    • On the bottom half of the casing, remove the two screws in the motherboard.
  6. Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 6、 1の画像 1
    • Carefully detach the wires from the motherboard, pulling slowly but firmly.
    • On the right hand side, the motherboard is attached to the ribbon. Do not pull too hard.
  7. Visioneer OneTouch 7400 USB Motherboard Replacement: 手順 7、 1の画像 1
    • Flip the motherboard over carefully.
    • Gently pull the ribbon out of its bed.
終わりに
作成者
6人の作成者と共同で作成されました。
Jena
メンバー登録日: 10/18/13
608 ポイント
6のガイドは作成済み
チーム
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013人のメンバー
UMAINE-DIAZ-F13S1G13
3 メンバー
17のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 464
