はじめに
If your glass in a vinyl window slider (2-3 pane) is broken, damaged, or in need of general replacement, use this guide to replace the glass pane itself.
A sash is the term which refers to the slider part of the window. They can come in many sizes from small windows to large glass patio doors! Typically they are square or rectangular and slide either horizontally or vertically inside a larger window frame along a track.
Every step of the guide requires you to handle and maneuver potentially broken glass which can be dangerous both from direct contact or from further cracking/breaking. Be sure to act carefully and thoughtfully while avoiding direct contact with the glass whenever possible and use hand protection whenever possible. The edges are very sharp and will cut you if you perform any kind of parallel or sliding motion across them.
必要な工具と部品
Remove the slider portion of the window from its frame and place it on a flat, soft work surface before beginning.
Using the non-beveled putty knife, insert the blade into the space between the frame and the stops (long, white strips).
Wriggle the knife back and forth to free up the stops and then pull the remaining length out by hand.
Flip the window over after removing all of the stops.
With the non-beveled putty knife, slip the edge of the knife between the frame and the pane itself.
Push as far back as you can and slide the knife along its length cutting the glazing tape's adhesive along all 4 sides.
Continue cutting and the glass should begin to or completely fall away from the frame.
Reinsert the stops by pushing them into the gap that holds them (this can usually be done with your fingers but these stops were very tight and needed some extra force).
You should hear a distinctive click when they are fully inserted and will be almost flush with the frame.
After all 4 stops are reinserted place the slider back in the larger window frame you took it from.
2 の人々がこのガイドを完成させました。
