メインコンテンツにスキップ
Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement
必要な工具と部品
  1. Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Back Cover Screws: 手順 1、 3の画像 1 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Back Cover Screws: 手順 1、 3の画像 2 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Back Cover Screws: 手順 1、 3の画像 3
    • Using your spudger or metal tweezers, work the rubber screw covers out of their sockets, found on each of the four corners of the back cover.
    • Have patience! These are held in with glue and can take time and a few attempts to remove.
    • Using a PH00 screwdriver, remove the 5.8mm screws found beneath each rubber cover (4 total).
  2. Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Pry Off Back Cover: 手順 2、 3の画像 1 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Pry Off Back Cover: 手順 2、 3の画像 2 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Pry Off Back Cover: 手順 2、 3の画像 3
    • Using the flat end of your prying tool, work the back cover away from the rest of the gTabet.
    • Starting near the charging port, work in one direction around the perimeter of the device.
    • Do not insert prying tool deeper than is necessary to separate back cover. You may damage other components!
    • Lift off back cover to reveal the interior of the device.
  3. Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Identify Battery & Prepare for Removal: 手順 3、 3の画像 1 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Identify Battery & Prepare for Removal: 手順 3、 3の画像 2 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Identify Battery & Prepare for Removal: 手順 3、 3の画像 3
    • The battery is the large black square that dominates much of the device interior.
    • There is tape holding several wires in place. This must be removed before the battery can be removed. Peel it gently; you will want to use it later.
  4. Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Disconnect Battery Power Cable: 手順 4、 3の画像 1 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Disconnect Battery Power Cable: 手順 4、 3の画像 2 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Disconnect Battery Power Cable: 手順 4、 3の画像 3
    • Using a PLASTIC tool of your choice, push both ends of the power cable connector, one at a time, away from its housing. This will slowly wiggle the connector out of place.
    • The white connector(red markup) comes off while the off white connector(orange markup) stays on the motherboard.
  5. Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Move Front-Facing Camera & Remove Battery: 手順 5、 3の画像 1 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Move Front-Facing Camera & Remove Battery: 手順 5、 3の画像 2 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Move Front-Facing Camera & Remove Battery: 手順 5、 3の画像 3
    • Using tweezers, remove the protective foam backing arch from the front-facing camera.
    • Pull the camera out of its housing and move it aside.
    • Be sure to move any wires out of the way before attempting to move the battery, as these are still connected and shouldn't be stressed!
    • Gently lift the battery up and away from the rest of the device and set it aside.
  6. Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Remove & Replace Front Facing Camera: 手順 6、 2の画像 1 Viewsonic gTablet UPC300-2.2 Front Facing Camera Replacement, Remove & Replace Front Facing Camera: 手順 6、 2の画像 2
    • The front-facing camera is held in by a tricky connector. It cannot be removed unless the two black tabs shown here are lifted. Once the tabs are lifted, you may gently pull the connector out with tweezers.
    • Replace the camera by reversing these steps.
    • Don't forget to push the black tabs back down after connecting a replacement camera!
終わりに
作成者
3人の作成者と共同で作成されました。
Cristian
メンバー登録日: 11/05/14
591 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-1, Miles Fall 2014 UMass Dartmouth, Team 4-1, Miles Fall 2014人のメンバー
UMASSD-MILES-F14S4G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 129
