Use your thumbs to pry the case apart.
It is easiest to pry the case apart if you start at the bottom.
The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
Once the bottom of the inner camera is pulled out, pull the device out completely.
Use a firm grasp when removing the device from the case for stability and control.
Orient the camera so that the LCD screen is facing you.
If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
Removing the casing completely is crucial to completing this guide.
Look for where the yellow electric strip is attached to the camera. You will find a plastic grey bar and a white base holding this strip in place.
Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed.
Remove the LCD screen from the camera. Make sure that the electric strip comes out with screen.
Turn the camera over to the side that once housed the LCD screen. Locate the electric strip near the top of the camera.
Holding the camera securely, gently pull the end of the electric strip off of the back of the camera using a pair of tweezers.
Using your fingers, fully detach the strip along with the casing. Be careful not to rip or tear any part of the electric strip.
Do not break or remove the black wire. This will damage the camera.
Orient the camera so that you are looking at the back of the camera. Directly above where the LCD screen was located, find the viewfinder cover clip.
Detach the clip with a pair of tweezers.
Push upwards and remove the viewfinder cover.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
