メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide is meant to teach the reader to install a new viewfinder mirror and lens. If the lens or mirror are no longer working or broken, this guide will help the reader replace them with new ones.
パーツ
パーツは指定されていません。
  1. Flip the camera over so the bottom is facing you. Flip the camera over so the bottom is facing you.
    • Flip the camera over so the bottom is facing you.
  2. Open the cover on the bottom by sliding it in the direction of the arrow. Open the cover on the bottom by sliding it in the direction of the arrow.
    • Open the cover on the bottom by sliding it in the direction of the arrow.
  3. Remove the batteries by pulling up on the top with your fingers.
    • Remove the batteries by pulling up on the top with your fingers.
  4. Unless otherwise stated, use a Phillips #00 screwdriver to remove screws.
    • Unless otherwise stated, use a Phillips #00 screwdriver to remove screws.
    • Remove the two 4.70mm screws in the bottom of the plastic casing.
  5. Remove the four 4.70mm screws in the left side of the camera. Remove the four 4.70mm screws in the left side of the camera.
    • Remove the four 4.70mm screws in the left side of the camera.
  6. Now on the side with the strap, remove the other four 4.70mm screws. Now on the side with the strap, remove the other four 4.70mm screws.
    • Now on the side with the strap, remove the other four 4.70mm screws.
  7. Use your thumbs to pry the case apart. It is easiest to pry to case apart if your start at the bottom. The case should come apart with minimal effort. If  it doesn't, you can use a tool such as a spudger or plastic opening tool.
    • Use your thumbs to pry the case apart.
    • It is easiest to pry to case apart if your start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a tool such as a spudger or plastic opening tool.
  8. This step requires a significant amount of force.
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of case about half an inch. This may be difficult and force is necessary.
  9. While pulling the camera out of the case, note the small soft plastic cover on the side of the camera. This cover will detach from the rest of the device. Once the bottom of the inner camera is pulled out about an inch and a half, pull the device out completely.
    • While pulling the camera out of the case, note the small soft plastic cover on the side of the camera. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out about an inch and a half, pull the device out completely.
    • When completely removing the device from the case, use a firm grasp with your hands for stability and control.
  10. Orient the camera so that the LCD screen is facing you.
    • Orient the camera so that the LCD screen is facing you.
    • If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
    • Removing the casing completely is crucial to completing this guide.
  11. Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame. Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame.
    • Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame.
  12. Allow the LCD screen to flip down. This will expose the electric strip that connects the screen to the camera.
    • Allow the LCD screen to flip down. This will expose the electric strip that connects the screen to the camera.
  13. Look for where the yellow electric strip is attached to the camera. You will find a plastic grey bar and a white base holding this strip in place.
    • Look for where the yellow electric strip is attached to the camera. You will find a plastic grey bar and a white base holding this strip in place.
    • Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
  14. Unplug the connected red and white wires. They will come out with the small white casing.
    • Unplug the connected red and white wires. They will come out with the small white casing.
  15. Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
    • Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
  16. Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed. Remove the LCD screen from the camera.  Make sure that the electric strip comes out with screen.
    • Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed.
    • Remove the LCD screen from the camera. Make sure that the electric strip comes out with screen.
  17. Remove the two screws securing the electric strip casing on the back of the camera.
    • Remove the two screws securing the electric strip casing on the back of the camera.
  18. Flip the camera over so that the top is facing you. This is the side with the main button.
    • Flip the camera over so that the top is facing you. This is the side with the main button.
    • Remove screws securing the electric strip casing near the speaker
  19. Flip the camera over so that the back is facing you. This is the side where the LCD screen used to be.
    • Flip the camera over so that the back is facing you. This is the side where the LCD screen used to be.
    • Pull the end of the electric strip off of the back of the camera with tweezers.
  20. Pull the electric strip off of the top of the camera with tweezers.
    • Pull the electric strip off of the top of the camera with tweezers.
    • By now, you should have two ends of the electric strip detached from the camera.
  21. Using your fingers, fully detach the strip along with the casing. This should come off easily. Be careful not to rip or tear any of the electric strip.
    • Using your fingers, fully detach the strip along with the casing. This should come off easily. Be careful not to rip or tear any of the electric strip.
    • The black wire should not be broken or removed. This will damage the camera.
  22. Orient the camera so that you are looking at the back of the camera. This is right above where the LCD screen used to be. Detach the clip of the viewfinder cover with the tweezers.
    • Orient the camera so that you are looking at the back of the camera. This is right above where the LCD screen used to be.
    • Detach the clip of the viewfinder cover with the tweezers.
    • Push up and remove the viewfinder cover.
  23. Remove the viewfinder mirror by pulling up on the mirror with tweezers.
    • Remove the viewfinder mirror by pulling up on the mirror with tweezers.
終わりに
3 の人々がこのガイドを完成させました。
Nick Oleskowicz
メンバー登録日: 2012年04月03日
269 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S15G13
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 2,763
