メインコンテンツにスキップ
Viasys Avea Battery Replacement
医療機器
この修理ガイドは医療機器メーカーからの是認を得ておらず、iFixitと医療機器メーカーは提携していません。
必要な工具と部品
  1. Viasys Avea Battery Replacement, Viasys Avea UIM and Plastic Cover Disassembly: 手順 1、 1の画像 1
    • Remove the ‘rubber collar’ located at the UIM rear neck, by grasping one of the two rubber tabs at the bottom. Pull firmly in an “arcing” motion.
    • Pull UIM forward and look for the Phillips Screw on the front arm cover. Remove (1) Phillips screw from the front arm cover. Remove the front arm cover.
    • Remove the two mounting screws now visible inside the ‘back arm cover’. Tilt the UIM down and remove the ‘back arm cover’.
  2. Viasys Avea Battery Replacement: 手順 4、 1の画像 1
    • Remove the (4) 11/32 KEP nuts that secure the ‘plastic top cover’ opening onto the chassis.
    • Remove (2) Phillips screws that secure the ‘plastic top cover’ to the rear chassis.
    • Slide the top ‘plastic top cover’ upward and forward away from the chassis.
    • Remove the (2) Phillips screws and washers that secure the HSSC Cable on the GDE. Unplug the HSSC Cable.
    • Carefully feed the HSSC Cable through the ‘plastic top cover’ opening.
    • While continuously supporting the UIM, remove (4) 3/8 nuts that fasten the UIM support arm onto the pneumatics.
    • Lift UIM off of pneumatics and set aside.
    • Remove plastic cover and set aside.
    • Check to see if the exhalation filter assembly is installed, if it is, remove the exhalation filter assembly.
    • Rotate the metal locking lever on the lower right of the ventilator body forward to an open position.
    • Remove the exhalation filter assembly from the ventilator body by pulling straight down.
    • Using a long Phillips screwdriver, remove the Phillips screw located at the top of the exhalation filter assembly well, if applicable.
    • Using a long Phillips screwdriver, remove the Phillips screw located at the exhalation port marked EXH, if applicable.
    • Using a long Phillips screwdriver, remove the Phillips screw from the outside of the plastic cover.
    • Using a long Phillips screwdriver, remove the Phillips screw on the font left wall.
    • Using a long Phillips screwdriver, remove the Phillips screw on the right side of the wall.
    • Set the plastic cover aside.
    • Using a long Phillips screwdriver, remove the 3 Phillips screws on the metal re-enforcement cover, if applicable, and set aside.
    • Remove the Exhalation Corner Assembly.
    • Locate metal top cover
    • Remove the 19 SEMS screws, (3) on the left side (5) on the right sife and (11) on top.
    • Remove metal top cover and set aside.
    • Disconnect the internal battery 2 pin Molex connector
  3. Viasys Avea Battery Replacement, Battery: 手順 15、 1の画像 1
    • Disconnect the internal batteries
    • Disconnect the battery fuse holder by pulling straight back on the two faston connectors.
    • Remove the fuse holder and fuse from the ventilator chassis using pliers to remove nut.
    • Remove the (3) 11/32 KEPS nuts that hold the battery bracket in place; (2) KEPS nuts on the bottom and (1) on the top.
    • Slide out the retaining bracket and the batteries.
    • Disconnect the positive and negative leads from the wire harness that connects to the driver transition board.
    • Cut both tie wraps that secure the battery monitor board and the 4-pin molex to the batteries.
    • Disconnect the batteries from each other.
終わりに
作成者
2人の作成者と共同で作成されました。
Anthony Hernandez
メンバー登録日: 05/04/20
394 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S1-G1, Zimmerman Spring 2020 Cal Poly, Team S1-G1, Zimmerman Spring 2020人のメンバー
CPSU-ZIMMERMAN-S20S1G1
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 14
今までの合計 358
