はじめに
Many houses, schools, apartments, restaurants have Vertical blinds. Most of the time those types of blinds tend to break or fall with the pass of the time. They are really easy to use and have a very good accessibility. We are used to recycling or substitute when something is breaking or in bad conditions. But, on this website ifixit.org, they gave us the idea to start fixing the stuff and not throwing it away or recycling them, because when we recycle not all of the material’s can be recycled fully and must be thrown away. So, we propose that this kind of blinds can be simply repairing. Just taking the blinds off and try to stick them and putting back into place. This required some materials, and this is an easy way to help the environment.
パーツ
パーツは指定されていません。
特集記事
  1. 1. Identify the problem with the blind.
    • 1. Identify the problem with the blind.
  2. 2. Use your hand to carefully remove the blind.
    • 2. Use your hand to carefully remove the blind.
  3. 3. Look at the part you took off and see if the problem is with the top part of the blind.
    • 3. Look at the part you took off and see if the problem is with the top part of the blind.
  4. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  5. 4. Make sure to have some glue or tape to fix the hole on top of the blind so you can be able to reassemble it.
    • 4. Make sure to have some glue or tape to fix the hole on top of the blind so you can be able to reassemble it.
  6. 5. Wait a few minutes for the glue to dry.
    • 5. Wait a few minutes for the glue to dry.
  7. 6. Reassemble the blind in the same place.
    • 6. Reassemble the blind in the same place.
  8. 7. Test the blinds by moving them side to side.
    • 7. Test the blinds by moving them side to side.
まとめ
Group 3
メンバー登録日: 2018年10月31日
145 ポイント
1ガイドが承認済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
