はじめに
Please ensure you have followed the prerequisite guide of removing the battery before proceeding with this guide.
  1. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
    • To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
  2. Carefully remove the battery from the phone by prying it from the top.
    • Carefully remove the battery from the phone by prying it from the top.
  3. With the opening tool, remove the rubber plugs from the screw holes around the screen.
    • With the opening tool, remove the rubber plugs from the screw holes around the screen.
  4. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  5. With a Philips screwdriver, remove the four screws from around the phone's screen.
    • With a Philips screwdriver, remove the four screws from around the phone's screen.
  6. Pry the top cover off the phone with a plastic opening tool.
    • Pry the top cover off the phone with a plastic opening tool.
  7. Remove the screen assembly from the phone.
    • Remove the screen assembly from the phone.
  8. With the opening tool, pry the circuit board off of the screen.
    • With the opening tool, pry the circuit board off of the screen.
まとめ
Corey Ryman
メンバー登録日: 2011年10月14日
255 ポイント
4のガイドは作成済み
チーム
James Madison, Team 2-4, Allen Fall 2011 James Madison, Team 2-4, Allen Fall 2011人のメンバー
JMU-ALLEN-F11S2G4
3 メンバー
8のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 944
