はじめに
The circuit board is home to many of the smaller parts of the Verizon M1424WR. These parts are soldered on to the circuit board, so in order to access them, you will need to remove the circuit board from the casing.
This router will have to be reauthenitcated with Verizon if you replace any WAN hardware or the whole board. Your new MAC address will not be approved.
  1. Flip the device so that the bottom is facing up.
    • Flip the device so that the bottom is facing up.
  2. Insert the plastic-opening tool under the silver labeled casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing. Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver. Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device. Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  6. Locate the two 10-mm screws on either side of the circuit board. Unscrew the two 10-mm screws using a Phillips #0 screwdriver. Keep track of the red rubber washer you remove from underneath one of the screws.
    • Locate the two 10-mm screws on either side of the circuit board.
    • Unscrew the two 10-mm screws using a Phillips #0 screwdriver.
    • Keep track of the red rubber washer you remove from underneath one of the screws.
  7. Lift the front of the circuit board up from the bottom casing.
    • Lift the front of the circuit board up from the bottom casing.
  8. Pull the circuit board towards you until it is separate from the bottom casing.
    • Pull the circuit board towards you until it is separate from the bottom casing.
まとめ
ある他の人がこのガイドを完成しました。
Jeffrey Fox
メンバー登録日: 2014年09月17日
326 ポイント
3のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-3, Mathis Fall 2014 University of Kentucky Louisville, Team 1-3, Mathis Fall 2014人のメンバー
LOUISVILLE-MATHIS-F14S1G3
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 382
