はじめに
Replace the antenna to address internet connection problems. This replacement is fast, simple, and requires no tools.
  1. Orient the router to where the back side with the ports faces you.
    • Orient the router to where the back side with the ports faces you.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Lower the antenna so that it is parallel to the table surface.
    • Lower the antenna so that it is parallel to the table surface.
  4. Unscrew the antenna counterclockwise at the threaded base until it is detached. Unscrew the antenna counterclockwise at the threaded base until it is detached.
    • Unscrew the antenna counterclockwise at the threaded base until it is detached.
まとめ
ある他の人がこのガイドを完成しました。
James Carby
メンバー登録日: 2014年09月17日
195 ポイント
1ガイドが承認済み
チーム
University of Kentucky Louisville, Team 1-3, Mathis Fall 2014 University of Kentucky Louisville, Team 1-3, Mathis Fall 2014人のメンバー
LOUISVILLE-MATHIS-F14S1G3
3 メンバー
4のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 263
