メインコンテンツにスキップ
Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement
必要な工具と部品
  1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: 手順 1、 2の画像 1 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: 手順 1、 2の画像 2
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 手順 2、 2の画像 1 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 手順 2、 2の画像 2
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 手順 3、 1の画像 1
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
終わりに
作成者
4人の作成者と共同で作成されました。
Analisa Caso
メンバー登録日: 10/08/18
232 ポイント
2のガイドは作成済み
チーム
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018人のメンバー
MARS-CHATERDON-F18S1G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 34
今までの合計 4,520
