メインコンテンツにスキップ
Verizon Ellipsis 7 Front Facing Camera Replacement
必要な工具と部品
  1. Verizon Ellipsis 7 Front Facing Camera Replacement, Charging Port: 手順 1、 3の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement, Charging Port: 手順 1、 3の画像 2 Verizon Ellipsis 7 Front Facing Camera Replacement, Charging Port: 手順 1、 3の画像 3
    • Hold down the power button until the screen goes black to turn off the device.
    • Remove the SIM card from the device to prevent damage.
    • To remove the SIM card, open the SIM card cover on the side of the device.
    • Push SIM card in and pull it out after hearing a click.
  2. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 2、 2の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 2、 2の画像 2
    • Take off the back panel.
    • Pry open the back cover carefully with a plastic opening tool.
    • Use the opening tool to disconnect the cover completely. Do not attempt to pry the back cover off with your hands.
    • Be sure to pry open all sides of the device. Attempting to take off the back cover when part of it is attached may snap the cover.
  3. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 3、 3の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 3、 3の画像 2 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 3、 3の画像 3
    • Remove the charging (micro-USB) port.
    • Unscrew the indicated screws using the Phillips #00 screwdriver.
    • The screws shown in the picture are the more common 4.76 mm.
    • Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
    • Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
    • Be extremely careful when disconnecting the ribbon cable. It is very delicate.
  4. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 4、 2の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 4、 2の画像 2
    • Remove the charging port board from the phone using tweezers.
    • Place the replacement charging port into the phone.
    • Be cautious when replacing the ribbon cable onto the new charging port board.
  5. Verizon Ellipsis 7 Front Facing Camera Replacement, Speaker: 手順 5、 2の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement, Speaker: 手順 5、 2の画像 2
    • Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
  6. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 6、 3の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 6、 3の画像 2 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 6、 3の画像 3
    • Using tweezers carefully lift the connector up to disconnect it from the motherboard.
    • Using tweezers carefully pull the speakers up and out of device.
  7. Verizon Ellipsis 7 Front Facing Camera Replacement, Front Facing Camera: 手順 7、 1の画像 1
    • Use tweezers to carefully disconnect the power cable bundle from the motherboard.
  8. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 8、 2の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 8、 2の画像 2
    • Remove the 10 screws from the motherboard using a Phillips #0 screwdriver.
    • The screws shown in the first picture is the more common 4.76 mm.
    • The screw shown in the second picture is shorter than the rest of the screws: 3.175 mm.
  9. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 9、 2の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 9、 2の画像 2
    • Using a spudger, remove the 5 antenna cable connectors from the motherboard.
  10. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 10、 3の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 10、 3の画像 2 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 10、 3の画像 3
    • Disconnect the two ZIF connectors that are connected to the motherboard with the spudger. Lift up the metal part of the connector and pull it off of its port
    • Once disconnected from the port, pull the metal part away from its connector carefully with the tweezers.
    • When all the connectors have been disconnected, you can gently lift the motherboard from the device.
  11. Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 11、 3の画像 1 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 11、 3の画像 2 Verizon Ellipsis 7 Front Facing Camera Replacement: 手順 11、 3の画像 3
    • Make sure the press lift connector is disconnected using the spudger, then carefully flip the motherboard over.
    • Disconnect the camera in the middle of the board using tweezers.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Anthony Arredondo
メンバー登録日: 10/10/16
412 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 12-7, Blackburne Fall 2016 Sam Houston State, Team 12-7, Blackburne Fall 2016人のメンバー
SHSU-BLACKBURNE-F16S12G7
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 550
