メインコンテンツにスキップ
Verizon Ellipsis 10 Speaker Replacement
必要な工具と部品
  1. Verizon Ellipsis 10 Speaker Replacement, Back Cover: 手順 1、 1の画像 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Speaker Replacement: 手順 2、 1の画像 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Speaker Replacement: 手順 3、 1の画像 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Speaker Replacement: 手順 4、 1の画像 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Speaker Replacement, Battery: 手順 5、 1の画像 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Speaker Replacement: 手順 6、 1の画像 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Speaker Replacement: 手順 7、 1の画像 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Speaker Replacement: 手順 8、 1の画像 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Speaker Replacement: 手順 9、 1の画像 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Speaker Replacement, Speaker: 手順 10、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the four M1.5 screws from the right speaker.
  11. Verizon Ellipsis 10 Speaker Replacement: 手順 11、 1の画像 1
    • Remove the black and white wires connected to the motherboard by pulling up on their connections.
    • Remove the three strips of tape.
  12. Verizon Ellipsis 10 Speaker Replacement: 手順 12、 1の画像 1
    • Remove the four M1.5 screws on the left speaker.
    • Remove the speakers from the device.
終わりに
作成者
4人の作成者と共同で作成されました。
Mary Duran
メンバー登録日: 04/03/19
597 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 142
