はじめに
This guide is designed to provide you with a visual and technical description to remove the battery of the Verizon Ellipsis 10.
必要な工具と部品
Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
もう少しです!
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
終わりに
3 の人々がこのガイドを完成させました。
