メインコンテンツにスキップ
Venturer CR20 Speaker Replacement
必要な工具と部品
  1. Venturer CR20 Speaker Replacement, Front Screen: 手順 1、 1の画像 1
    • On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
  2. Venturer CR20 Speaker Replacement: 手順 2、 2の画像 1 Venturer CR20 Speaker Replacement: 手順 2、 2の画像 2
    • Using a moderate amount of force, position the screwdriver in the crack between the front screen and the main body of the clock (as shown) and push the screen away from the main body of the clock.
  3. Venturer CR20 Speaker Replacement, Power Cord: 手順 3、 2の画像 1 Venturer CR20 Speaker Replacement, Power Cord: 手順 3、 2の画像 2
    • Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
  4. Venturer CR20 Speaker Replacement: 手順 4、 3の画像 1 Venturer CR20 Speaker Replacement: 手順 4、 3の画像 2 Venturer CR20 Speaker Replacement: 手順 4、 3の画像 3
    • Using your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
  5. Venturer CR20 Speaker Replacement, Tuner Wheel: 手順 5、 1の画像 1
    • Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
  6. Venturer CR20 Speaker Replacement: 手順 6、 2の画像 1 Venturer CR20 Speaker Replacement: 手順 6、 2の画像 2
    • Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
  7. Venturer CR20 Speaker Replacement: 手順 7、 3の画像 1 Venturer CR20 Speaker Replacement: 手順 7、 3の画像 2 Venturer CR20 Speaker Replacement: 手順 7、 3の画像 3
    • Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together.
    • Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard.
    • Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
  8. Venturer CR20 Speaker Replacement: 手順 8、 3の画像 1 Venturer CR20 Speaker Replacement: 手順 8、 3の画像 2 Venturer CR20 Speaker Replacement: 手順 8、 3の画像 3
    • Gently, pull the tuner wheel up and away from the motherboard.
  9. Venturer CR20 Speaker Replacement, Speaker: 手順 9、 3の画像 1 Venturer CR20 Speaker Replacement, Speaker: 手順 9、 3の画像 2 Venturer CR20 Speaker Replacement, Speaker: 手順 9、 3の画像 3
    • Flip over the motherboard and grab hold of the plastic frame.
    • With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing.
終わりに
作成者
3人の作成者と共同で作成されました。
Robert Myers
メンバー登録日: 01/11/13
54 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-15, Forte Winter 2013 Cal Poly, Team 5-15, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G15
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 322
