メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
In this guide, you will learn how to remove and install the power cord of your alarm clock. The process consists of removing the front screen, followed by taking the hardware out of the housing and detaching the power cord.
パーツ
パーツは指定されていません。
  1. Locate and unscrew the single 2mm Phillips screw from the clock.
    • Locate and unscrew the single 2mm Phillips screw from the clock.
  2. Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock. Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock.
    • Using a moderate amount of force, position the screwdriver in the crack of the front screen (as shown) and push away from the clock.
  3. Manta Driver Kit
    どんな修理にでも対応可能な112ビット
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Get a good grip on the hardware within the shell and pull it all out. Get a good grip on the hardware within the shell and pull it all out.
    • Get a good grip on the hardware within the shell and pull it all out.
  5. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock. With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
    • With your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
終わりに
ある他の人がこのガイドを完成しました。
Robert Myers
メンバー登録日: 2013年01月11日
54 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 5-15, Forte Winter 2013 Cal Poly, Team 5-15, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G15
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 251
