メインコンテンツにスキップ
Vent/Bleed Coolant System on BMW E60/E90
ビデオの概要
    • Insert key in the dash or steering column.
    • With foot OFF the brake (don't want to start the car), push the start button (headlamps and interior systems come on).
    • Turn both temp dials as high as they will go and put the fan on the lowest setting.
    • Push the accelerator pedal in for ten seconds then let go - you will hear the water pump cycle on.
    • Set a timer for 12-15 minutes. In this time period, you will hear the water pump cycle on and off and coolant gurgling at the reservoir.
    • After 12-15 minutes turn the car off, remove the reservoir cap and check the fluid - it should be slightly below where you started.
    • Start your car. Watch your temperature. If the car will run without overheating you're done. If you will notice that the temperature is rising repeat these steps.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
lifeoftech
メンバー登録日: 11/04/09
187 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 23
過去 7 日: 126
過去 30 日: 474
今までの合計 26,690
